Returns the rate-shaping parameters for all QoS profiles on the specified ports to the default values.
| port_list | Specifies the ports on which to unconfigure QoS profiles. |
| all | Specifies that this command applies to all ports on the device. |
Minimum bandwidth—0%
Maximum bandwidth—100%
The default values for egress priority and ingress QoS profiles differ by platform as described in the following sections.
Maximum buffer—100% (as set by the configure qosprofile command)
Maximum buffer override—100% (as set by the configure qosprofile command)
Weight—1
WRED—See the configure qosprofile wred command description.
None.
unconfigure qosprofile
This command was first available in ExtremeXOS 11.0.
The egress and ports parameters are available only on all platforms.
